Screen out of place on monitor
Jolanpiep
65
Hey guys,
I just installed my new GPU (750ti) new motherboard and CPU. But iv'e got a problem. This is not new. I already had this problem with my previous GPU (r7 240). The screen has moved diagonally slightly for about 0.5cm. That doesn't sound like much but actually I can't read some things or things disappear of my screen. I tried adjusting it with Nvidia Control Panel but it only moves the screen within the area it is in now, so it doesn't change anything to the black bars I have on two sides. My mouse is also not able to cross the black bars, it's really as if my screen has moves but the monitor stayed on the same place. This is a picture of what it looks like. Just copy paste I think:
http://tinypic.com/view.php?pic=28bqjiw&s=8#.VLBI2mTF8mc
Does your monitor have auto-adjust? Most monitors do. Try finding that button or setting.
Run the monitors native resolution. If that doesn't work, completely remove graphics card drivers with DDU.
http://www.wagnardmobile.com/DDU/info.html
Think it enters safe mode and removes the drivers. After that reinstall nvidias drivers.
If it still doesn't work, check if you can find monitor drivers on the manufacturers homepage.
Ill try this when I get home :)
