Screen Resolution Problem with AMD R9-270X graphics card. Desperate!!
ReeceW17
4
Hi,
I am having severe problems with trying to get my resolution to work on my new PC.
I have a AMD R9-270X graphics card but when my HDMi cable is plugged into this the resolution goes to 1680x1050.
I have tried setting it to 1080p on the Catalyst Control Centre but it leaves black borders around the screen. I have tried other cables and monitors.
The only way get the correct resolution setting is to plug my cable into the normal slot so it uses Intel graphics but doesn't that mean my PC is using its graphics card?
Any help or suggestions would be appreciated.
Thanks.
Yes I have tried but the correct resolution doesn't seem to work.
I have this monitor http://www.cclonline.com/product/89593/UM-FG6EE-B01/Monitors/Acer-G6-Series-G246HLBbid-24-inch-Full-HD-LED-Monitor/MON1083/
