Screen Resolution Problem
Ahmed_139
Commendable
Oct 3, 2016
I have a Lenovo 24" display screen which was working perfectly fine, and then suddenly the quality decreased dramatically. i asked a local supplier and he said it's a cable problem so i bought a new one and it worked fine for 4 days and then the same problem happened.
i'm using a normal VGA cable to connect the monitor.
i've been searching online for this problem yet with no luck of even identifying it.
below is a screenshot i took with snipping tool:
https://ibb.co/gik7xJ
Appreciate your support!
