Screen won't fit monitor
Stijn Hendriks
75
Using laptop with intel HD graphics 5600
Via HDMI to a old PnP BenQ FP222WH
1280x720p resolution is recommended but it doesn't fit.
using 1920x1080p fits the screen better but the screen is too big, my windows search bar is outside the screen for example.
windows 10 with Hd 5600 graphics.
underscanning doesn't work for me and the resolution 1600x900p doesn't excist on this monitor..
please help
Sometimes you have to resize manually.
I use nvidia for it, but if you dont have it you need to learn how to do it with hd graphics.
To resize with nvidia you go to Nvidia Contro Panel > Adjust desktop size and position >Size > Resize
Must be something similar
i only get the 3d options... no desktop or else, i've looked up some vids about how to do it but i dont get the adjust desktop size..
thanks for the reply
The link gives an error just like the first one xD
but i switched monitors with an old computer i got and that one worked correctly
it is the same size and same age but some unkown brand... at least it works 😛
thanks
