Question Screwed into motherboard is it fixable?!?
Mar 25, 2023
I made a huge mistake, of screwing in a tray to a vinyl cutter machine I have. Without thinking I grabbed the only screws I had available and installed this tray, I imagine I was to use blunt ended short screws (but the machine is 15 years old and I don't have manual or parts that came with it) . And then my machine wouldn't turn on. After inspecting and wondering why it wasn't working I realized I had screwed them right into the motherboard of the machine. And it won't work.
I don't know how to attach pictures, but you can see small holes in the back of the motherboard.
Is there any miracle cure to fix this or did I just make a $2500 mistake??
