I screwed up my computer by upgrading my Windows 8.1 to 10; I then had a problem with Windows 10, and tried to restore 8.1. Now when I try to start, I see nothing at all on my monitor, just a brief shimmer of light, then blackness. Hitting F12 at startup does nothing, as does inserting a Dell backup and recovery dvd, as well as a Dell bootable flash drive.
I'm getting desperate, so my thought is that if my OS is somehow screwed up, would it work if I removed the hard drive, re-formatted it with another computer, and then put bootable instructions on it, reinstall on my original computer and then power up? Would this work? If anyone has had to do anything similar, or if anyone can help with advice on how to do this correctly, I would be very grateful.
