Hello, recently I installed the Arctic liquid freezer II 360 Aio for my lga 1700 Socket z690 board and I had an issue with the screws that came with it specifically the ones for the mounting clips. The manual showed that I’m suppose to use the longer screws for the mounting clips but I could not get those to fit what so ever so I ended up using the shorter screws that the manual says is for the radiator since these screws fit with almost no effort as opposed to the longer one. At the time of installation I thought that all the long screws can be used for any mounting clip because they all look very similar, but apparently the AMD mounting clip screws are slightly different and maybe these were the ones I was trying to use and that’s why they wouldn’t fit. My question now is, is there any harm in keeping the aio installed as it is with he shorter screws used for the mounting clips or should I go through the hassle of taking everything out and try fitting the longer screws onto the mounting clips again? Thank you
