Scythe Fuma SCFM-1000 Big Air CPU Cooler Review
Why weren't coolers which were priced similarly also in this test? Now we know how this cooler performs against big-air but what about the cheaper ones? How would it perform against those? What would be the best cooler under $50 and so on.
How could the Dark Rock Pro be quitest cooler with its insane 2100 rpm? Something is wrong here.
Na, nothing wrong, they use their latest Silentwings series fans with it iirc, which tend to run quiet, though at the cost of overall efficiency, RPMs, CFM. The DRP 3 has proven to be among the best air coolers, it runs quieter than some of its closest competitors, though not always cooler.
"Does it fit the Ncase M1?"
Ncase M1 Cooler Height restriction = 130mm with side bracket in place and no fan mounted (according to their page), so, the cooler in this review, or anything that's considered a big cooler, would be a no fit. Even many mid sized air coolers wouldn't fit the M1.
Another aspect that's hard to factor is the difference between rated specs and real world. The dark rock pro 3 can get fairly audible if the fans are spinning full speed but it took a lot of doing to push them there in real world use. My 4690k is oc'd to 4.6ghz and I had to run prime95 v26.6 small fft's as well as turn off every single case fan in order to force it to ramp the fans up. It's not very realistic to run p95 on an oc'd processor with no active case ventilation.
Under normal circumstances with the stock 200mm intake fan (which isn't the best for airflow performance) and stock 140mm exhaust on the enthoo pro running at around 7v and two noctua 140mm fans running at around 5-7v, the dark rock pro 3 never becomes audible either while gaming or running p95 with a decent overclock.
The specs for the dark rock pro 3 fans may be off in this article. As far as I know the fans included with the cooler aren't the same as those sold retail. The cooler specs from bequiet say they're silent wings fans, not silent wings 2 or 3 which are what they sell retail. They also don't offer retail 135mm fans which the drp3 uses, they only offer 120 or 140mm fans. The drp3 cooler specs say the fan speeds are 1400rpm for the 135mm and 1700rpm for the 120mm at 100% pwm speed. Not 2k rpm +. They do have a silent wings 3 high speed 120mm pwm fan that runs 2200rpm at 28.6dba but it's not the one included with the cooler.
The same may go for the other coolers, if they're able to cool the cpu in the conditions in which it's used without reaching 100% fan speed then the loudest fan rating may not apply in real world use. Just because it says a cooler 'can be' xyz dba doesn't mean it will be. A max noise rating of 30dba doesn't matter much if under normal conditions it only runs at 25-50% fan speed and stays under 20dba.
For the price the fuma seems to do pretty well. It depends on what it's being compared to, other coolers of the same height or smaller for size constraints? Ram interference? Performance at that price level? There are similarly priced coolers like the reeven justice or thermalright true spirit 140 power that will potentially outperform it at $40-50 but if height is an issue the fuma would be the better choice as it's shorter than either of those. If ram clearance at that price point is an issue but cooler height isn't, the true spirit 140 power or cryorig h5 universal might be better options.
Thanks for clarifying the DRP3 fan stats, and good points made in your post in general fwiw.
I was expecting a Noctua NH-D15 in there, to be able to tell how much better or worse it is than what would arguably be either THE or one of the best and most popular air coolers out there.
Just curious:
Why don't you do test acoustic efficiency at either equal noise levels (lower temp = better acoustic efficiency) or equal temp (lower noise level = better acoustic efficiency)?
Either of those would serve as a much better way to see how coolers stack up against each other, and testing at equal noise levels would be very easy to do.
A relatively mild overclock setting to really push these coolers. People who get into these larger coolers are going for more overclock and voltage settings. Anyway an excellent review. We can never have too many cooler reviews out there.
For those wondering how this cooler measures up to others at lower tiers, here's how it stacked up on Frostytech's test... exactly a year ago today as a matter of fact: http://www.frostytech.com/articleview.cfm?articleid=2794&page=6
Hi Thomas,
I think it is time to go for a thorough and updated LP Air Cooler review. There are some interesting products from Cryorig, Scythe, Arctic, Phanteks and more. In my limited time and quick study (only two builds), I found that they are delivering quite a good performance under non-OCing and non-Gaming work loads.
I reckon LP coolers are great value for the money, plus no more heavy and ugly blocks, and say goodbye to Liquid AIOs! What do you think?
