tonyn1 :
This is driving me nuts! I bought a low priced lap top, an Asus EEE PC 1215P. It was cheap and I didn't want to spend too much on one. It only had 1G of memory, which I increased to the max 2G, which helped quite a bit, but it is still running a little bit slower than I'd like. I want to use Readyboost to help it out, but I'm having trouble finding an SD card that will work in it. I tried a Patriot LX Series 16 GB Class 10 SDHC Flash Memory Card PSF16GSDHC10 which I thought would work fine for this, but Windows 7 said it was not suitable or something like that when I clicked the Readyboost option. I don't know why, as that is a pretty high speed card. I try doing a search for ReadyBoost compatible SD cards and lots of results come up, but none of them say anywhere on the page or on the card that they are ReadyBoost compatible. How can I find one that is and what size should I get?
_____________________________________________________________________________________________________
tonyn1 :
apparently Class 4 sdmc cards will work if you have a class 10 there is a hack to make that work, open regedit, START BUTTON Search box at bottom enter REGEDIT then this path...
HKEY_LOCAL-MACHINE, SOFTWARE, Microsoft, Windows NT, current version, EDMgmt
you will see several SDMC cards that begin with ?? (2 question marks) right click on all of these and delete the entries.
restart windows wirh SDMC card in slot now re open regedit and fololow same path
HKEY_LOCAL-MACHINE,SOFTWARE,Microsoft,Windows NT,current version,EDMgmt
there will be a new entry at the top of the list with 2 ?, this is your card, select it then select device ststus and change the entry from 1 to 2
close regedit
now you have a class 10 card running capable of READYBOOST
