sd card problem
kkris
i inserted new sd card in to my tablet it did detect card but in manage application options there is no move to sd card button at all android clean master cannot move applications to sd card too any ideas .
I would look at the size of the SD Card if it is a size that is not compatible with the version of android you are using it will not recognize it. Also if the sd card is formatted for mac or something else it will not recognize the card either. Try checking to see if the size is ok and that the card is properly formatted.
