I record events using multiple camera and devices that use 250GB SD cards for storage. All cards read at above 95MB/s which is the slowest one. The fastest is 200MB/s. I can only get the computer to recognize 3 readers at a time. Using Windows 10 Home and pro and Windows 11 Home and pro and on two different computers.
The problem goes like this; I stick 3 SD cards in the readers and start downloading them to a 16TB storage disk. Each SD card reads above 60MB/s (total 180MB/s which matches the destination drive speed) and when one finishes, the remaining two go up to 90MB/sec each. Which is great, it is working as expected... until one more SD Card finishes. With one SD Card left the read speed drops to 30MB/sec. It does this no matter which SD card happens to be the last one. For some reason two or more read normal, but a single reads at 30MB/sec.
It looks like a software issue. I have tried many readers and get the same results. Just bought a new computer and still get the same results on both computers with one running Windows 10pro and one running windows 11pro. Also, just putting one SD Card in starts at 30MB/s but speeds up to 90MB/s when one more SD card is started then down to 60 when the third one is started. The issue is only when one SD card is being read.
I am wondering if it is some setting that makes two or more reader activity a higher priority and only one reader active a lower priority... You know... making more room for advertising and information gathering. Of all the post I have seen state the obvious; But this is not normal. 3 SD cards reading (180MB/s total) are each 2x faster then a single reader uploading @ 30MB/s to storage that should be uploading @ 180MB/s.
Any one having a solution would be greatly appreciated.
