Seagate 1tb small external hard drive isnt showing up on my laptop
Paige-Holly
it was working fine . i plugged it into my tv and was working fine then this morning i turned the tv on and went to use it but it was coming up as a recording device so i switched it to a different usb port and it wouldnt come up at all . i then put it into my laptop and nothings coming up . please help
If you decide not to send it off to a DR company...
If affordable, if possible, boot a usb or dvd backup/restore/clone utility, one of your choosing, and clone your source HD onto an external target HD. Put that target HD in a safe place, in case more drastic recovery attempts are needed. Meanwhile, there are numerous free and pay-for data recovery utilities and there are many threads all over The 'Net that can guide you through DR.
It is not uncommon for these drives to get stuck heads, though the issue may be more of a logical one. If the data is important, you really should seek professional data recovery assistance. It likely won't cost more than a few hundred USD.
A few labs I recommend are:
Recovery Force
Data-Medics
PCImage
On the off chance that the issue is with formatting, you can try R-studio. But, I read your description that the drive not being physically seen, suggesting physical issues.
Good luck!
