Hey guys, first time poster here. I couldn't find a question similar to mine when searching, so here we go. Apologies if this has been asked before.
I've been having issues with a Seagate 3tb External (model 9SEAN3-500) randomly disconnecting from it's USB port for a few weeks now. It seems to happen when the disc is in the middle of a read or write cycle. I've run all the tests on Seatools: Long and short generic, plus the short drive self test. It passed the generic ones just fine, but failed the short DST with an error code of A499D5EC. I was told by a seagate tech that the short DST tests for r/w cycles while the other two do not.
Also, when it does disconnect randomly, my explorer window and any app that was reading/writing to the drive hangs, and I have to power cycle my computer to restart it. I've had this same result on both my desktop (Win7 ult, i5-3570k, 8gb ram. Assembled it with one of the fantastic guides here btw, thanks! ) and my laptop (Asus x83vm), so I'm assuming it's the HDD itself.
This all leads me to believe that the enclosure is most likely faulty, correct? I would have no problem disassembling it and just putting it in my tower as a SATA HDD, but since it is still under warranty, I figured I'd ask you guys first. I do have a lot of data on there that I would rather not lose in an RMA though, and I do not have sufficient data space to back it up, unfortunately. Please let me know what you think. Sorry if I forgot anything, and thanks in advance.
