Hi everyone
I have an issue with my seagate 4tb external hard drive, not sure if this is the right place to post about it.
Basically i have copied some of my movies into the drive and when i play them they lag a bit, doesnt matter if i play it normally or skip 10 to 20 secs it lags.
I have already tried the below steps :
- update the drivers ( they were already updated when i first plugged the drive)
- did a quick format
- did a self test and a fix all long and short from the seagate tool pc app to check for bad sectors but the result came clean ( took 13hrs to do the fix all long)
- checked for disk fragmentation but doesn't require fragmentation as it shows 0% fragmented
Edit
- the cable is fine
- the usb port is fine
- vlc player updated
- to my surprise i connected the drive to another older hp laptop and the movies are working fine without any lag but in my hp omen it lags, i cant say that the laptop has issues because my other wd 5tb hard drives play movies completely fine while connected only seagate has issues but then again the older hp laptop plays it fine
So confused🙁
Please note i have an hp omen gaming laptop so its pretty fast
Any suggestions please let me know
Thank you
Edit
- the cable is fine
So confused🙁
Thank you
