Seagate 600 Pro-Series 200 GB SSD Review: For The Enterprise
1. Would it have made sense to add more DRAM to increase performance ? On a SSD this expensive, 1GB RAM would hardly add 20$ or so.
2. On the first page, the fourth paragraph :"Today, Seagate ........... bench today."
You completely went over my head. It appears you are just throwing names around. Maybe reword that para again ? or explain here ? :)
WD bought SiliconSystems in 2009 and has been making WD branded SiliconDrives. I put one in my i5 build shortly after they came out, and I feel like I am the only one who bought one for home use. They still make them, but are focusing on embedded systems at this point. Maybe Seagate will have more luck, but there are a lot of well established players already. I'm pretty luke-warm on Seagate. How do you know your Seagate SSD is on the verge of failure without the telltale Seagate Click of Death®?
[citation][nom]mayankleoboy1[/nom]1. Would it have made sense to add more DRAM to increase performance ? On a SSD this expensive, 1GB RAM would hardly add 20$ or so.2. On the first page, the fourth paragraph :"Today, Seagate ........... bench today." You completely went over my head. It appears you are just throwing names around. Maybe reword that para again ? or explain here ?[/citation]
1) With the DRAM-to-NAND ratio already being 1MB->1GB it is already fairly aggressive, it may have helped with performance consistency, but I don't think you would see much improvement.
2) Basically, Seagate announced 4 products today
a) Seagate 600 Pro - Entry level, read-focused, enterprise SSD
b) Seagate 600 - Consumer SSD, which we will have reviewed tomorrow
c) Seagate 1200 - High-end, dual-port, 12Gbps SAS SSD
d) X8 Accelerator - High-end plug-in PCIe SSD
Hope this helps.
Drew
[citation][nom]Lrxst[/nom]WD bought SiliconSystems in 2009 and has been making WD branded SiliconDrives. I put one in my i5 build shortly after they came out, and I feel like I am the only one who bought one for home use. They still make them, but are focusing on embedded systems at this point. Maybe Seagate will have more luck, but there are a lot of well established players already. I'm pretty luke-warm on Seagate. How do you know your Seagate SSD is on the verge of failure without the telltale Seagate Click of Death®?[/citation]
You're the one that bought that drive 🙂 You are right on point with WD/Silicon Systems. They were primarily an embedded flash vendor prior to acquisition. If you look at their webpage, you will see that they only offer SLC-based drives.
[citation][nom]drewriley[/nom]1) With the DRAM-to-NAND ratio already being 1MB->1GB it is already fairly aggressive, it may have helped with performance consistency, but I don't think you would see much improvement.2) Basically, Seagate announced 4 products today a) Seagate 600 Pro - Entry level, read-focused, enterprise SSD b) Seagate 600 - Consumer SSD, which we will have reviewed tomorrow c) Seagate 1200 - High-end, dual-port, 12Gbps SAS SSD d) X8 Accelerator - High-end plug-in PCIe SSDHope this helps.Drew[/citation]
Thanks, Drew. This made the paragraph clearer.
I have had several Seagate drives in the past and they both had reliability issues after their first year. Right now, Seagate is on my Do Not Buy List!!!! For any magnetic hard drive, I would select WD. Have had pretty good luck with that company. When any company produces parts that fail prematurely and then don't supply a replacement promptly, then they are on my DNB List. I will probably buy a Samsung SSD shortly, since with Samsung I have always had good performance and reliability.
