Seagate Backup Plus Slim USB cable
Hi there Nikhil08,
I guess any USB 3.0 cable no longer than 12'' will be fine.
It will not hurt to contact the manufacturer as well. :)
Cheers,
D_Know_WD
you're lucky - i threw mine away after discovering my transfer speeds to my seagate backup slim plus external HDDs went up after using a better quality USB 3.0 cable. The cable supplied with your seagate is awfully thin guage wire, the heavier guage cables are the way to go
and as D_Know_WD stated, keep the replacement cable to a 12-15" length
fwiw
Nikhil08
6
It's Slim version of backup plus drive , Male B connector is thin so any cable won't work.
