my new computer has 2 usb 3 ports at the front and 4 at the back. i have found that some of the ports seem faster than others when i transfer a movie from my pc to the backup slim and some even start to transfer then stop half way through and one will not work at all . i tested this with the same movie on all ports with mixed results and came to the conclusion that i had faulty usb ports . the Seagate worked fine on my old hp envy desktop. i did the same test with a sandisk extreme usb flash drive and it works fine on all the ports with a speed of 165 mbs and the one that the seagate did work on only got about 80mbs . i have ordered a new usb wire that connects the seagate to the pc to see if it helps. i have also checked the drive for errors and its fine. i did notice that while the seagate was connected to my pc and the file transfer window was open showing me the file had stopped half way through it made my windows 10 start button unresponsive and my clock on the bottom right of the desktop vanished and it would not even let me shut the pc down so i had to use the reset button on the stryker case , after it rebooted the pc was fine until i tried another movie transfer using the seagate and the same unresponsiveness happened again
can someone please tell me what is going on with the seagate . are my usb 3 connections faulty ? like i said before i had no problem on my hp envy's usb 3 ports. my new pc is made by zoostorm and has the new intel i7 6700k Skylake with a asrock z170 pro4s motherboard and 32 gb of gskill 2400mhz ram and a gtx 980TI gpu and its all fitted in a coolermaster stryker case . i just thought i should mention the spec if it helps to sort out my problem . thanks in advance
