Seagate Baracuda 2TB Drive- Not Detected
1WaffleIron
26
  • Intel Core i7-3930K 3.2GHz 6-Core Processor
    Asus P9X79 LE ATX LGA2011 Motherboard
    Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
    SAMSUNG 840 Series MZ-7TD120BW 2.5" 120GB SATA III Solid State Drive
So, last night I finished my first Pc build and aside from the issue I'm dealing with, things went well. I installed Windows onto my SSD and then connected my HDD after the install was completed. When I booted things up everything was fine, only problem was that my 2TB drive did not show up in My Computer. It's been attached via SATA 6.0, 3.0 and whatever the other normal data plug would be. I've already tried reattaching all of the cables plugged into the drive and I don't really have a fix. In my BIOS menu I don't see the drive in the main Drive area though I do see it listed when I go and look through the boot sections. Not sure what the issue is but would like to know how to go about fixing this.
Heh i just went into the BIOS to check on stuff and even though it was already set to ACHI mode, I decided to just switch it off and on. So now that I switched it off and on, i can format the disk in Disk Management. Thanks a lot!
i have the same exact problem right now with the same exact hard drive, i have tried everything to find the prob and now coming here to see you have legit the same exact problems as me i will try the same thing you did truning that option off and on. did you turn the option off and save the settings and boot up then shut it off and turn it on?
