S subin1388 Prominent Aug 2, 2017 2 0 510 Aug 2, 2017 #1 Hi All, Can anyone tell me, whether i can connect a Seagate Pipeline 1TB with a Seagate Barracuda 2TB. Also what are the other factors that i would have to look for if i need to connect them in a stack.
Solution popatim Aug 5, 2017 You can install both within the same system. I'm not sure what you mean by "connect it to" the barracuda. If you are intending to game from this, I would definitely recommend a 7200rpm drive instead of this.
popatim Titan Moderator Dec 2, 2009 39,135 1,041 136,890 Aug 5, 2017 Solution #2 You can install both within the same system. I'm not sure what you mean by "connect it to" the barracuda. If you are intending to game from this, I would definitely recommend a 7200rpm drive instead of this. Upvote 0 Downvote Solution
