I bought a 1 TB Seagate Barracuda 7200 rpm SATA drive about 5 months ago and I never have quite gotten it working correctly and am not sure what the issue is. I installed it in my PC to upgrade my storage situation from the older 150 GB IDE drive that I was using before as my primary master drive. I now have win 7 installed on both drives and can boot either installation from the boot manager. My goal was basically to flip flop over to the using the new faster and larger 1TB SATA drive as the primary master and then erase the operating system on the other drive and use it specifically as backup storage. However after unplugging the IDE drive, the operating system on the new SATA drive will not boot. I get an error that says primary hard drive not detected. Furthermore, When the IDE drive is plugged in by itself it is recognized as the master, however the sata cannot be recognized without the older IDE drive being plugged in. I'm pretty sure that the computer is recognizing both drives so why do they both need to be plugged in for the SATA drive to run properly?
Tomorrow I get the rest of the parts for my new i7 rig so I want to make sure I can boot this drive properly and reformat it for a fresh install on the new system. Anyone else have this issue? I'm sure its probably a simple fix and I probably installed windows incorrectly or something. Thank you for your time and input.
-Justin
-Justin
