Seagate external hard drive not recognizable
joslinh
Please help! I have an old Seagate 60 GB hard drive that is no longer recognizable by any computer. It doesn't show up in my computer or disk manager but in device manager, a message pops up under unknown devices saying, "Cypress AT2LP RC42". Is anyone familiar with this and/or know how to fix it?
As Philip brings up, "removing drive from enclosure" is about your next step. I don't know this model of enclosure but, in the last 8 years or so, Seagate's used a plastic clamshell design (top piece, bottom piece) that are clipped together with real, genuine plastic. So I have to snap those off (crack!) by inserting a flat-head screwdriver into a side-seam, and twisting it. Probably at the corners, first.
Some had 4 clips, some 6.
But first, I'd look for screw-holes deep on the underside or back of the case. Any dark dank hole is probably a bolt-hole, probably philips-head type.
Once you get the case open, there will be a few screws to undo and the hard drive can be extracted.
At this point, I'd open up my computer...
At this point, I'd open up my computer and plug in the power-connector to it, and hold the hard-drive in my hand to see if I could detect 'motion', vibrations - anything to indicate life!
If so, then you can buy a new external case (well, an old IDE version) and insert the drive there, or you might get a USB-to-IDE/SATA converter kit and attach the drive as a bare external.
Thanks Christine and Phillip. Acutally when I plug it in, it does show signs of life (lights and spinning) so I'm hoping all is not lost. I will do as you've suggested and cross my fingers. Thanks!
