JaredDM :
1. Seatools is pretty useless, so I don't know why you're bothering with it. Instead just check the SMART info using a tool like Crystal Disk Info (google it) and see what it's showing for errors on your drives.
2. There's nothing "safe" about a drive that's already developing bad sectors. In fact there is nothing safe about a Seagate drive ever. They fail suddenly, often without warning. So if you're getting some warning, hurry up and backup your important data and dump the drive.
I strongly recommend you stop buying Seagate drives. Their failure rates are nearly 4 times what other companies like Toshiba or HGST are showing.
ok, so crystaldisk says the following:
Should I be really worried? or is this a moderate salvageable problem?
CrystalDiskInfo 6.5.2 (C) 2008-2015 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Professional SP1 [6.1 Build 7601] (x64)
Date : 2015/12/05 22:48:29
-- Controller Map ----------------------------------------------------------
- Ricoh Memory Stick Controller [ATA]
+ Intel(R) ICH9M-E/M SATA AHCI Controller [ATA]
- HL-DT-ST DVDRAM GSA-U20N
- HITACHI HTS722016K9SA00
+ Ricoh SD Host Controller [ATA]
- Ricoh SD/MMC Disk Device
- Ricoh SD/MMC Host Controller [ATA]
- Ricoh xD-Picture Card Controller [ATA]
-- Disk List ---------------------------------------------------------------
(1) HITACHI HTS722016K9SA00 : 160.0 GB [0/0/1, pd1]
(2) ST31000528AS : 1000.2 GB [2/X/X, sa1] (V=0BC2, P=3008) - st
(2) ST31000528AS
Enclosure : Seagate FreeAgent USB Device (V=0BC2, P=3008, sa1) - st
Model : ST31000528AS
Firmware : CC38
Serial Number : 5VP24KGX
Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : 7200 RPM
Interface : USB (Serial ATA)
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
Transfer Mode : ---- | SATA/300
Power On Hours : 20310 hours
Power On Count : 138 count
Temperature : 28 C (82 F)
Health Status : Caution
Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
APM Level : ----
AAM Level : FE00h [ON]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 116 _95 __6 000006C0D971 Read Error Rate
03 _95 _94 __0 000000000000 Spin-Up Time
04 100 100 _20 000000000262 Start/Stop Count
05 _98 _98 _36 00000000007A Reallocated Sectors Count
07 _69 _60 _30 000000730F12 Seek Error Rate
09 _77 _77 __0 000000004F56 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C 100 100 _20 00000000008A Power Cycle Count
B7 100 100 __0 000000000000 Vendor Specific
B8 100 100 _99 000000000000 End-to-End Error
BB __1 __1 __0 000000000962 Reported Uncorrectable Errors
BC 100 _98 __0 000000040007 Command Timeout
BD 100 100 __0 000000000000 High Fly Writes
BE _72 _33 _45 047B1C1C001C Airflow Temperature
C2 _28 _67 __0 00100000001C Temperature
C3 _50 _32 __0 000006C0D971 Hardware ECC recovered
C5 _74 _73 __0 000000000440 Current Pending Sector Count
C6 _74 _73 __0 000000000440 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
F0 100 253 __0 F3390000032C Head Flying Hours
F1 100 253 __0 000013F965C9 Total Host Writes
F2 100 253 __0 0000DDA04784 Total Host Reads
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0C5A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 2020 2020 3556 5032 344B 4758
020: 0000 0000 0004 4343 3338 2020 2020 5354 3331 3030
030: 3035 3238 4153 2020 2020 2020 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0010
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 0506 0000 0048 0040
080: 01F0 0029 346B 7F01 4163 3469 BE01 4163 407F 0052
090: 0052 0000 FFFE 0000 FE00 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 0000 0000 5000 C500
110: 1C56 29AB 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 6DB0
130: 7470 6DB0 7470 2020 0002 0140 0100 5000 3C06 3C0A
140: 0000 003C 0000 0008 0000 0000 004F 0280 0000 0000
150: 0008 0000 0000 0000 0000 0000 0000 0000 3F00 9800
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 103F 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 1010 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 36A5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 0A 00 01 0F 00 74 5F 71 D9 C0 06 00 00 00 03 03
010: 00 5F 5E 00 00 00 00 00 00 00 04 32 00 64 64 62
020: 02 00 00 00 00 00 05 33 00 62 62 7A 00 00 00 00
030: 00 00 07 0F 00 45 3C 12 0F 73 00 00 00 00 09 32
040: 00 4D 4D 56 4F 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0C 32 00 64 64 8A 00 00 00 00
060: 00 00 B7 32 00 64 64 00 00 00 00 00 00 00 B8 32
070: 00 64 64 00 00 00 00 00 00 00 BB 32 00 01 01 62
080: 09 00 00 00 00 00 BC 32 00 64 62 07 00 04 00 00
090: 00 00 BD 3A 00 64 64 00 00 00 00 00 00 00 BE 22
0A0: 00 48 21 1C 00 1C 1C 7B 04 00 C2 22 00 1C 43 1C
0B0: 00 00 00 10 00 00 C3 1A 00 32 20 71 D9 C0 06 00
0C0: 00 00 C5 12 00 4A 49 40 04 00 00 00 00 00 C6 10
0D0: 00 4A 49 40 04 00 00 00 00 00 C7 3E 00 C8 C8 00
0E0: 00 00 00 00 00 00 F0 00 00 64 FD 2C 03 00 00 39
0F0: F3 13 F1 00 00 64 FD C9 65 F9 13 00 00 00 F2 00
100: 00 64 FD 84 47 A0 DD 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 58 02 00 7B
170: 03 00 01 00 01 AF 02 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 41 00 00 00 02 05 06 05 06 05 05 05
190: 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 4F 1A E7 CA 84 42 00 00
1B0: 00 00 00 00 01 00 A3 08 C9 65 F9 13 60 00 00 00
1C0: 84 47 A0 DD 6D 0E 00 00 00 00 00 00 B9 66 40 00
1D0: 00 00 00 CA 00 00 00 00 E5 02 00 00 24 00 05 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A6
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00
010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00
020: 00 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00
030: 00 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00
050: 00 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00
060: 00 00 B7 00 00 00 00 00 00 00 00 00 00 00 B8 63
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00
080: 00 00 00 00 00 00 BC 00 00 00 00 00 00 00 00 00
090: 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 BE 2D
0A0: 00 00 00 00 00 00 00 00 00 00 C2 00 00 00 00 00
0B0: 00 00 00 00 00 00 C3 00 00 00 00 00 00 00 00 00
0C0: 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 C6 00
0D0: 00 00 00 00 00 00 00 00 00 00 C7 00 00 00 00 00
0E0: 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00
0F0: 00 00 F1 00 00 00 00 00 00 00 00 00 00 00 F2 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60
