Question Seagate Hard Disk Noise
Aug 7, 2023
6
Hi,
I just bought an used 8TB Seagate Exos HD and I although seems to works fine what caught my attention is that on startup it makes very weird sounds, this is the first time I bought a seagate hd and also the first time I bought used storage, with smaller (2TB) WD hd's never heard such weird sounds. It's normal?
I tested the disk with Seatools and it passed the short and long test. Also checked it with CrystalDiskInfo and HD Sentinel and seems to be Ok too but I don't understand to much of the parameters listed in the results. Here are screenshoots of both apps
CrystalDiskInfo
Hardware ECC recovered incresed only once from 1 to 13 then remained in that number
Commad timeout changed from 1 to 100 in "current"
Hd Sentinel Health status
This number "1173" didn't increase since I bought the disk so I assume that errors occurred in the past during a cable problem
HD Sentinel SMART info
Is there something that I should worried about? Thanks in advance for any help.
I can't reach any of the ibb.co URLs.
HD Sentinel is reporting a problematic raw value for the Command Timeout attribute.
0x00070007FFFF -> 0x0007 / 0x0007 / 0xFFFF
This number consists of three components. The first is telling you that there were 7 occasions when the drive required more than 7 seconds to respond to a read/write request. The last number has hit its maximum value, so that would worry me.
Seagate SMART Attribute Specification:
http://t1.daumcdn.net/brunch/service/user/axm/file/zRYOdwPu3OMoKYmBOby1fEEQEbU.pdf
http://www.hddoracle.com/download/file.php?id=5129
Normal SATA SMART Attribute Behavior (Seagate):
http://t1.daumcdn.net/brunch/service/user/axm/file/Vw3RJSZllYbDc86ssL6bofiL4r0.pdf
http://www.hddoracle.com/download/file.php?id=5130
Thanks for reply fzabkar, I reauploaded the screencaps, can you see any other bad new?
I just search for "command tryout" and google says " is a critical SMART parameter that indicates a problem with the power supply", this seems to be coherent with the fact that it has 1173 communication problems due to power issues. Could it be that the psu on the system where it was before I bought it was failing causing these problems and now that the hd is being powered by a new psu this is no longer happening? or is this some sort of warning that no matter what psu I use the disk is already damaged?
Command Timeouts are not a PSU problem.
Those Ultra DMA CRC Errors are due to problems related to the SATA interface, either a cable issue or an issue with the SATA port.
The ECC On The Fly Count numbers are always low for current models, so this attribute is not a good indicator of actual problems.
Thank you so much for your help and for clarifying these things for me! The cables seems to be fine (maybe they wasn't in the system of the previous owner of the disk), all my other WD disks work without problems and present no errors at all. perhaps the sata connector on the seagate disk is defective.
HD Sentinel complete report
Code:
-- Physical Disk Information - Disk: #1: ST8000NM000A-2KE101 --
    Hard Disk Summary
    Hard Disk Number . . . . . . . . . . . . . . . . : 1
    Interface  . . . . . . . . . . . . . . . . . . . : S-ATA Gen3, 6 Gbps
    Disk Controller  . . . . . . . . . . . . . . . . : Controladora SATA AHCI estándar (AHCI) [VEN: 1022, DEV: 7901] Version: 10.0.19041.1889, 6-21-2006
    Disk Location  . . . . . . . . . . . . . . . . . : Bus Number 1, Target Id 0, LUN 0
    Hard Disk Model ID . . . . . . . . . . . . . . . : ST8000NM000A-2KE101
    Firmware Revision  . . . . . . . . . . . . . . . : SN03
    Hard Disk Serial Number  . . . . . . . . . . . . : WSD1BXMB
    Total Size . . . . . . . . . . . . . . . . . . . : 7630882 MB
    Power State  . . . . . . . . . . . . . . . . . . : Active
    Device Type  . . . . . . . . . . . . . . . . . . : Fixed Disk
    Logical Drive(s) . . . . . . . . . . . . . . . . : Z: [Storage]
    Current Temperature  . . . . . . . . . . . . . . : 21 °C
    Maximum Temperature (Ever Measured)  . . . . . . : 45 °C, 2/8/2023 21:43:37
    Minimum Temperature (Ever Measured)  . . . . . . : 17 °C, 7/8/2023 21:54:46
    Maximum Temperature (During Entire Lifespan) . . : 55 °C
    Power On Time  . . . . . . . . . . . . . . . . . : 514 days, 12 hours
    Estimated Remaining Lifetime . . . . . . . . . . : more than 1000 days
    Health . . . . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
    Performance  . . . . . . . . . . . . . . . . . . : #################### 100 % (Excellent)
    Problems occurred between the communication of the disk and the host 1173 times.
    In case of sudden system crash, reboot, blue-screen-of-death, inaccessible file(s)/folder(s), it is recommended to verify data and power cables, connections - and if possible try different cables to prevent further problems.
    More information: [url=https://www.hdsentinel.com/hard_disk_case_communication_error.php]https://www.hdsentinel.com/hard_disk_case_communication_error.php[/url]
      No actions needed.
    ATA Information
    Hard Disk Cylinders  . . . . . . . . . . . . . . : 15504021
    Hard Disk Heads  . . . . . . . . . . . . . . . . : 16
    Hard Disk Sectors  . . . . . . . . . . . . . . . : 63
    ATA Revision . . . . . . . . . . . . . . . . . . : ACS-4
    Transport Version  . . . . . . . . . . . . . . . : SATA Rev 3.3
    Total Sectors  . . . . . . . . . . . . . . . . . : 1953506646
    Bytes Per Sector . . . . . . . . . . . . . . . . : 4096 [Advanced Format]
    Multiple Sectors . . . . . . . . . . . . . . . . : 16
    Error Correction Bytes . . . . . . . . . . . . . : 0
    Unformatted Capacity . . . . . . . . . . . . . . : 7630885 MB
    Maximum PIO Mode . . . . . . . . . . . . . . . . : 4
    Maximum Multiword DMA Mode . . . . . . . . . . . : 2
    Highest Possible Transfer Rate . . . . . . . . . : S-ATA Gen3 Signaling Speed (6 Gps)
    Negotiated Transfer Rate . . . . . . . . . . . . : S-ATA Gen3 Signaling Speed (6 Gps)
    Minimum Multiword DMA Transfer Time  . . . . . . : 120 ns
    Recommended Multiword DMA Transfer Time  . . . . : 120 ns
    Minimum PIO Transfer Time Without IORDY  . . . . : 120 ns
    Minimum PIO Transfer Time With IORDY . . . . . . : 120 ns
    ATA Control Byte . . . . . . . . . . . . . . . . : Valid
    ATA Checksum Value . . . . . . . . . . . . . . . : Valid
    Acoustic Management Configuration
    Acoustic Management  . . . . . . . . . . . . . . : Not supported
    Acoustic Management  . . . . . . . . . . . . . . : Disabled
    Current Acoustic Level . . . . . . . . . . . . . : Default (00h)
    Recommended Acoustic Level . . . . . . . . . . . : Max performance and volume (FEh)
    ATA Features
    Read Ahead Buffer  . . . . . . . . . . . . . . . : Supported, Enabled
    DMA  . . . . . . . . . . . . . . . . . . . . . . : Supported
    Ultra DMA  . . . . . . . . . . . . . . . . . . . : Supported
    S.M.A.R.T. . . . . . . . . . . . . . . . . . . . : Supported
    Power Management . . . . . . . . . . . . . . . . : Supported
    Write Cache  . . . . . . . . . . . . . . . . . . : Supported
    Host Protected Area  . . . . . . . . . . . . . . : Not supported
    HPA Security Extensions  . . . . . . . . . . . . : Supported
    Advanced Power Management  . . . . . . . . . . . : Not supported
    Extended Power Management  . . . . . . . . . . . : Supported, Enabled
    Power Up In Standby  . . . . . . . . . . . . . . : Supported
    48-Bit LBA Addressing  . . . . . . . . . . . . . : Supported
    Device Configuration Overlay . . . . . . . . . . : Not supported
    IORDY Support  . . . . . . . . . . . . . . . . . : Supported
    Read/Write DMA Queue . . . . . . . . . . . . . . : Not supported
    NOP Command  . . . . . . . . . . . . . . . . . . : Not supported
    Trusted Computing  . . . . . . . . . . . . . . . : Not supported
    64-Bit World Wide ID . . . . . . . . . . . . . . : 5000C500C96F5A43
    Streaming  . . . . . . . . . . . . . . . . . . . : Supported
    Media Card Pass Through  . . . . . . . . . . . . : Not supported
    General Purpose Logging  . . . . . . . . . . . . : Supported
    Error Logging  . . . . . . . . . . . . . . . . . : Supported
    CFA Feature Set  . . . . . . . . . . . . . . . . : Not supported
    CFast Device . . . . . . . . . . . . . . . . . . : Not supported
    Long Physical Sectors (8)  . . . . . . . . . . . : Supported
    Long Logical Sectors . . . . . . . . . . . . . . : Not supported
    Write-Read-Verify  . . . . . . . . . . . . . . . : Supported, Disabled
    NV Cache Feature . . . . . . . . . . . . . . . . : Not supported
    NV Cache Power Mode  . . . . . . . . . . . . . . : Not supported
    NV Cache Size  . . . . . . . . . . . . . . . . . : Not supported
    Free-fall Control  . . . . . . . . . . . . . . . : Not supported
    Free-fall Control Sensitivity  . . . . . . . . . : Not supported
    Service Interrupt  . . . . . . . . . . . . . . . : Not supported
    IDLE IMMEDIATE Command With UNLOAD Feature . . . : Supported
    Zoned Capabilities . . . . . . . . . . . . . . . : Not supported
    SCT Command Transport  . . . . . . . . . . . . . : Supported
    SCT Error Recovery Control . . . . . . . . . . . : Supported
    Nominal Media Rotation Rate  . . . . . . . . . . : 7200 RPM
    Nominal Form Factor  . . . . . . . . . . . . . . : 3.5 inch
    SSD Features
    Data Set Management  . . . . . . . . . . . . . . : Not supported
    TRIM Command . . . . . . . . . . . . . . . . . . : Not supported
    Deterministic Read After TRIM  . . . . . . . . . : Not supported
    Read Zeroes After TRIM . . . . . . . . . . . . . : Not supported
    S.M.A.R.T. Details
    Off-line Data Collection Status  . . . . . . . . : Successfully Completed
    Self Test Execution Status . . . . . . . . . . . : Successfully Completed
    Total Time To Complete Off-line Data Collection  : 567 seconds
    Execute Off-line Immediate . . . . . . . . . . . : Supported
    Abort/restart Off-line By Host . . . . . . . . . : Not supported
    Off-line Read Scanning . . . . . . . . . . . . . : Supported
    Short Self-test  . . . . . . . . . . . . . . . . : Supported
    Extended Self-test . . . . . . . . . . . . . . . : Supported
    Conveyance Self-test . . . . . . . . . . . . . . : Supported
    Selective Self-Test  . . . . . . . . . . . . . . : Supported
    Save Data Before/After Power Saving Mode . . . . : Supported
    Enable/Disable Attribute Autosave  . . . . . . . : Supported
    Error Logging Capability . . . . . . . . . . . . : Supported
    Short Self-test Estimated Time . . . . . . . . . : 1 minutes
    Extended Self-test Estimated Time  . . . . . . . : 731 minutes
    Conveyance Self-test Estimated Time  . . . . . . : 2 minutes
    Last Short Self-test Result  . . . . . . . . . . : Never Started
    Last Short Self-test Date  . . . . . . . . . . . : Never Started
    Last Extended Self-test Result . . . . . . . . . : Never Started
    Last Extended Self-test Date . . . . . . . . . . : Never Started
    Last Conveyance Self-test Result . . . . . . . . : Never Started
    Last Conveyance Self-test Date . . . . . . . . . : Never Started
    Security Mode
    Security Mode  . . . . . . . . . . . . . . . . . : Supported
    Security Erase . . . . . . . . . . . . . . . . . : Supported
    Security Erase Time  . . . . . . . . . . . . . . : 732 minutes
    Security Enhanced Erase Feature  . . . . . . . . : Supported
    Security Enhanced Erase Time . . . . . . . . . . : 732 minutes
    Security Enabled . . . . . . . . . . . . . . . . : No
    Security Locked  . . . . . . . . . . . . . . . . : No
    Security Frozen  . . . . . . . . . . . . . . . . : Yes
    Security Counter Expired . . . . . . . . . . . . : No
    Security Level . . . . . . . . . . . . . . . . . : High
    Device Encrypts All User Data  . . . . . . . . . : No
    Sanitize . . . . . . . . . . . . . . . . . . . . : Supported
    Overwrite  . . . . . . . . . . . . . . . . . . . : Supported
    Crypto Scramble  . . . . . . . . . . . . . . . . : Not supported
    Block Erase  . . . . . . . . . . . . . . . . . . : Not supported
    Sanitize Antifreeze Lock . . . . . . . . . . . . : Supported
    ACS-3 Commands Allowed By Sanitize . . . . . . . : Yes
    Serial ATA Features
    S-ATA Compliance . . . . . . . . . . . . . . . . : Yes
    S-ATA I Signaling Speed (1.5 Gps)  . . . . . . . : Supported
    S-ATA II Signaling Speed (3 Gps) . . . . . . . . : Supported
    S-ATA Gen3 Signaling Speed (6 Gps) . . . . . . . : Supported
    Receipt Of Power Management Requests From Host . : Not supported
    PHY Event Counters . . . . . . . . . . . . . . . : Supported
    Non-Zero Buffer Offsets In DMA Setup FIS . . . . : Not supported
    DMA Setup Auto-Activate Optimization . . . . . . : Supported, Disabled
    Device Initiating Interface Power Management . . : Supported, Disabled
    In-Order Data Delivery . . . . . . . . . . . . . : Not supported
    Asynchronous Notification  . . . . . . . . . . . : Not supported
    Software Settings Preservation . . . . . . . . . : Supported, Enabled
    Native Command Queuing (NCQ) . . . . . . . . . . : Supported
    Queue Length . . . . . . . . . . . . . . . . . . : 32
    NCQ Streaming  . . . . . . . . . . . . . . . . . : Not supported
    NCQ Autosense  . . . . . . . . . . . . . . . . . : Supported
    Automatic Partial To Slumber Translations  . . . : Not supported
    Rebuild Assist . . . . . . . . . . . . . . . . . : Supported, Disabled
    Hybrid Information . . . . . . . . . . . . . . . : Not supported
    Device Sleep (DevSleep)  . . . . . . . . . . . . : Not supported
    DevSleep To ReducedPwrState  . . . . . . . . . . : Not supported
    Disk Information
    Disk Family  . . . . . . . . . . . . . . . . . . : Exos 7E8
    Form Factor  . . . . . . . . . . . . . . . . . . : 3.5"
    Capacity . . . . . . . . . . . . . . . . . . . . : 8 TB (8 x 1.000.000.000.000 bytes)
    Number Of Disks  . . . . . . . . . . . . . . . . : ?
    Number Of Heads  . . . . . . . . . . . . . . . . : ?
    Rotational Speed . . . . . . . . . . . . . . . . : 7200 RPM
    Rotation Time  . . . . . . . . . . . . . . . . . : 8,33 ms
    Average Rotational Latency . . . . . . . . . . . : 4,17 ms
    Disk Interface . . . . . . . . . . . . . . . . . : Serial-ATA/600
    Buffer-Host Max. Rate  . . . . . . . . . . . . . : 600 MB/seconds
    Buffer Size  . . . . . . . . . . . . . . . . . . : 262144 KB
    Drive Ready Time (Typical) . . . . . . . . . . . : ? seconds
    Average Seek Time  . . . . . . . . . . . . . . . : ? ms
    Track To Track Seek Time . . . . . . . . . . . . : ? ms
    Full Stroke Seek Time  . . . . . . . . . . . . . : ? ms
    Width  . . . . . . . . . . . . . . . . . . . . . : 101,9 mm (4,0 inch)
    Depth  . . . . . . . . . . . . . . . . . . . . . : 147,0 mm (5,8 inch)
    Height . . . . . . . . . . . . . . . . . . . . . : 26,1 mm (1,0 inch)
    Weight . . . . . . . . . . . . . . . . . . . . . : 716 grams (1,6 pounds)
    Required Power For Spinup  . . . . . . . . . . . : ? mA
    Power Required (Seek)  . . . . . . . . . . . . . : 12,8 W
    Power Required (Idle)  . . . . . . . . . . . . . : 7,6 W
    Power Required (Standby) . . . . . . . . . . . . : ? W
    S.M.A.R.T.
No.  Attribute                Thre.. Value  Worst  Data                Status                   Flags
1    Raw Read Error Rate      44     82     64     161122843           OK                       Error-Rate, Performance, Statistical, Critical
3    Spin Up Time             0      90     90     0                   OK (Always passing)      Statistical, Critical
4    Start/Stop Count         20     100    100    281                 OK                       Self Preserving, Event Count, Statistical
5    Reallocated Sectors Co.. 10     100    100    0                   OK                       Self Preserving, Event Count, Statistical, Critical
7    Seek Error Rate          45     75     60     35384631            OK                       Error-Rate, Performance, Statistical, Critical
9    Power On Time Count      0      86     86     12348               OK (Always passing)      Self Preserving, Event Count, Statistical
10   Spin Retry Count         97     100    100    0                   OK                       Event Count, Statistical, Critical
12   Drive Power Cycle Count  20     100    100    114                 OK                       Self Preserving, Event Count, Statistical
18   Head Health Self Asses.. 50     100    100    0                   OK                       Error-Rate, Statistical, Critical
187  Reported Uncorrectable.. 0      100    100    0                   OK (Always passing)      Self Preserving, Event Count, Statistical
188  Command Timeout          0      100    1      524287              OK (Always passing)      Self Preserving, Event Count, Statistical
190  Airflow Temperature      40     79     45     21                  OK                       Self Preserving, Statistical
192  Power off Retract Cycl.. 0      100    100    45                  OK (Always passing)      Self Preserving, Event Count, Statistical
193  Load/Unload Cycle Count  0      61     61     79076               OK (Always passing)      Self Preserving, Event Count, Statistical
194  Disk Temperature         0      21     55     15; 21              OK (Always passing)      Self Preserving, Statistical
195  Hardware ECC Recovered   0      13     1      161122843           OK (Always passing)      Event Count, Error-Rate, Statistical
197  Current Pending Sector.. 0      100    100    0                   OK (Always passing)      Event Count, Statistical
198  Off-Line Uncorrectable.. 0      100    100    0                   OK (Always passing)      Event Count
199  Ultra ATA CRC Error Co.. 0      200    178    1173                OK (Always passing)      Self Preserving, Event Count, Error-Rate, Performanc..
240  Head Flying Hours        0      100    253    2856                OK (Always passing)
241  Total LBA Written        0      100    253    39782514162         OK (Always passing)
242  Total LBA Read           0      100    253    1671592783          OK (Always passing)
    Transfer Rate Information
    Total Data Read  . . . . . . . . . . . . . . . . : 0 MB,  1 MB since installation  (2/8/2023)
    Total Data Write . . . . . . . . . . . . . . . . : 0 MB,  0 MB since installation
    Average Reads Per Day  . . . . . . . . . . . . . : 0,17 MB
    Average Writes Per Day . . . . . . . . . . . . . : 0,00 MB
    Current Transfer Rate  . . . . . . . . . . . . . : 0 KB/s
    Maximum Transfer Rate  . . . . . . . . . . . . . : 0 KB/s
    Current Read Rate  . . . . . . . . . . . . . . . : 0 KB/s
    Current Write Rate . . . . . . . . . . . . . . . : 0 KB/s
    Current Disk Activity  . . . . . . . . . . . . . : 0 %
[code/]
Based on what you see, would you advise me to return the disc?
I suspect that the SATA link isn't the best for 6Gbps. If the drive were to drop back to 3Gbps, I expect that UDMA CRC Errors would go away. In any case, these errors are automatically corrected by retransmission of the affected data.
The only thing that would concern me are the Command Timeouts.
SATA cables came with the motherboard, an asus proart x570 (kind of mid/high end mobo), same cables are used with other WD disks and don't report any issue.
Many of the errors that appear in the report came with the disk, meaning that happened where the disk was installed in the previous's owner system, probably a system with defective cables.
This is a screenshot of Crystaldiskinfo from when I plugged it for the first time in my pc, you can see that those values in the command timeout parameter were already there and didn't change it since then.
I had the disk for about 15 days, during this time only the numbers in "ultra ATA CRC error" and "Read error rate" changed, and sincerely aside for the weird noise at the start I didn't experienced data lost, problems to move files, bsods, etc. I can have it another 15 days for testing it before decide if I return it and get the money back or I keep it.
From GSmartControl
Code:
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (  567) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 731) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x70bd)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   079   064   044    -    77461199
  3 Spin_Up_Time            PO----   090   090   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    282
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   076   060   045    -    39775698
  9 Power_On_Hours          -O--CK   086   086   000    -    12361
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    115
 18 Unknown_Attribute       PO-R--   100   100   050    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   001   000    -    30065295359
190 Airflow_Temperature_Cel -O---K   078   045   040    -    22 (Min/Max 17/22)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    45
193 Load_Cycle_Count        -O--CK   061   061   000    -    79104
194 Temperature_Celsius     -O---K   022   055   000    -    22 (0 15 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   009   001   000    -    77461199
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   178   000    -    1173
240 Head_Flying_Hours       ------   100   253   000    -    2867 (225 207 0)
241 Total_LBAs_Written      ------   100   253   000    -    39782515330
242 Total_LBAs_Read         ------   100   253   000    -    17302179483
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             115  ---  Lifetime Power-On Resets
0x01  0x010  4           12361  ---  Power-on Hours
0x01  0x018  6     39782513642  ---  Logical Sectors Written
0x01  0x020  6       155902329  ---  Number of Write Commands
0x01  0x028  6     17300836292  ---  Logical Sectors Read
0x01  0x030  6        94281232  ---  Number of Read Commands
0x01  0x038  6   1691339618397  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           10140  ---  Spindle Motor Power-on Hours
0x03  0x010  4            8288  ---  Head Flying Hours
0x03  0x018  4           79104  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4              42  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4          104750  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              22  ---  Current Temperature
0x05  0x010  1              42  ---  Average Short Term Temperature
0x05  0x018  1              42  ---  Average Long Term Temperature
0x05  0x020  1              55  ---  Highest Temperature
0x05  0x028  1              15  ---  Lowest Temperature
0x05  0x030  1              52  ---  Highest Average Short Term Temperature
0x05  0x038  1              23  ---  Lowest Average Short Term Temperature
0x05  0x040  1              49  ---  Highest Average Long Term Temperature
0x05  0x048  1              38  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4          111567  ---  Number of Hardware Resets
0x06  0x010  4              37  ---  Number of ASR Events
0x06  0x018  4            1185  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x010  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
Any red flag?
HD Sentinel surface est
