Hi. I've been trying for the past couple of days and I am not getting anywhere. I'm hoping someone here can help. About a month ago upon boot, I got a a SMART error. I found it was my 750GB drive that was my second data drive. I immediately turned it off and unplugged the drive, to hopefully prevent further damage. I ordered a replacement 3TB drive, but hadn't had a chance to install it until last Sunday. I thought since the drive wasn't making any noise I'd be able to just copy the files (about 400GB worth) to the replacement drive, remove the platters from the old drive, throw it away and be done with it. Well, that didn't happen. Here's what I tried:
1. I've tried CHKDSK (freezes at 36%).
2. I've tried UBCD (HDAT2, Seatools, PartedMagic). All were failures. Seatools did give me "9da5976b" error code.
3. I then proceeded to Ubuntu (live mode) and tried DDRESCUE. I was able to recover about 3GB, then it just stopped. After 9 hours, I cancelled it.
4. I was able to copy some files from Ubuntu's file manager (even though Windows 7 wouldn't). However, after a while the drive unmounted itself and when I tried to remount, I got I/O errors.
5. Moved on to Hiren's Boot CD. I was able to recover some more from Mini XP. Eventually got I/O error and "semaphore has timed out" error. Drive disappeared. At this point, I checked the BIOS and it had completely disappeared from the BIOS. Reappears after power cycle. I enabled hot-plugging in hopes that if it disconnected, the BIOS would be able to find it again and reconnect.
6. Went back to Ubuntu. I was able to copy some more files. This is when I discovered that there was in fact some important files that I hadn't backed up. So far there are 1,100 camera pictures. Every program I wrote with Visual Studio is also on there. The rest is probably unimportant stuff, but I haven't been able to read the drive to find out.
The drive model is a Seagate Barracuda 750GB ST3750840SCE. I was thinking that since there's not a bunch of bad sectors, but instead I/O errors and disappearing from the BIOS, the problem is in the PCB, not the platters or the head. Would I be able to swap the PCB to a working one on this drive? Doesn't PCB swapping help with I/O errors, or is this lost cause (other than professional data recover)?
