Seasonic G-550 PSU enough for my system?
The quality of XFX Pro is high, higher than many others, look here:
http://www.tomshardware.com/forum/id-1804779/power-supply-unit-tier-list.html
G series is the same tier as Pro, but yes its a bit higher in quality, but XFX is NOT low quality, very reliable too.
I strongly recommend you to get a higherr wattage PSU than extremely high quality one. Don't worry about XFX's quality, its good enough. EVGA 650G is very high quality too.
PS: XFX is made by SeaSonic.
The PSU is extremely high quality, but the GPU with other hardware will really be pushing it to its limits, upgrade recommended. The system has 42A on 12V recommended but the demand is too high for safe and sound long term usage. Have you considered the 150W TDP and more powerful GTX 970?
290 max peak usage is like 250-300w and 4670k @ 4.8 is ~160w (so mine is probably liie 140w)
I dont think ill ever get those numbers in regular use. 😀
(I mainly use my PC for gaming & occasional streaming)
