Seasonic G360W Gold Power Supply
you need 2x6pin power cables for that gpu. the seasonic g360w is great but providing 1x6pin cannot run that gpu. best option is.
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($59.99 @ Newegg)
Total: $59.99
(Generated by PCPartPicker 2014-06-07 10:48 EDT-0400)
haswell ready and with enough room for overclocking.
Total: $59.99
Traciatim
It seems like it would be pushing it a bit, but that PSU is rated for the full 360 watts on it's 12v rails alone. I know my own 3570k witha GTX670 only pulls a shade above 300 watts from the wall, which is about 270-275 delivered to the machine... Your design would put it at pretty similar power usage, and 275 watts would be less than the 'rule of thumb' 80% capacity.
You'd be really cutting off your upgrading options though, but it should power it just fine.
