I bought a "opened but never used" GX 1300W Prime Seasonic Gold 80+ from ebay from Scan computers (well known and reliable PC shop in UK) it was very cheap, but the only problem is that it had a few less cables than I desired, I already own a M12II Evo 850W bronze 80+ with all the cable set, I was wondering if the cables are interchangeable ? as the M12II Evo is a old discontinued unit compared to the GX 1300 Prime. What I found on the official Seasonic website is this:
https://seasonic.com/cable-compatibility
If you scroll all the way down to discontinued series, you will see the M12II Evo showing green dots on all compatible cable reference numbers and the same can be soon in the GX Prime series (if you scroll all the way up) so just to make 100% sure are these two cables interchangeable ? and if worst come scenario what will happen ? PSU will auto shut off ? and not burn my rig down or components ? or start a fire ? do PSU have some safety feature in this scenario, just in case ?
And what is the difference between the older M12II cables with the newer models like GX 1300 prime ? any significant improvements ? Also when I check my M12II cable reference numbers it says something like; (for example on the PCIE-E connectors
"1G13" but on the website it shows reference numbers as "xG13" I,m assuming the "x" does not mean much right ? the "x" just means some batch number or something, the "G13" is the important one to look out for ??
Kind Regards
Kind Regards
