Seatools for windows Problem or HHD problem?
Maxcodes
32
Hey I was so when i was playing world of tanks i started hearing a ticking noise and i thought it was one of the fans and i didnt care much. But strangely it was only there when WoT was the active windows, so i tried to start Seatools to check if it was a problem with my disk, but then when it checked for drivers it suddenly froze and so did windows, i tried pressing ctrl + alt + del but that didn't work so i shut down the computer. When it had restarted i tried running seatools again and same problem.. So i was wondering if it could be my HDD, which is a 1 TB SSHD from Seagate.
Zero re-allocated sectors is good - HDTune should also state that the disk is healthy.
My Seatools won't run on my Seagate HDD. I don't use it.
I'll run them now and i'll update on this later!
I also ran a error scan and it showed 0 errors so i'll guess that its just something wrong with Seatools..
Yes correct. Same with my Seatools.
