I recently bought a new 28" 4k monitor (Crossover 289k) to replace an older 1080p BenQ monitor. When I first set it up, I noticed no performance issues. Now, it is causing extreme FPS drops in video games and videos that are **NOT** running on that monitor at all. For instance, I'll start up a game that I can usually run at 60+ FPS, and now find it running at ~4-10 FPS. I would understand this happening if I were trying to run this rendered in 4k on that monitor, but this is still outputting to my laptop's main screen. Even with nothing displayed on the 4k monitor, I run into this issue. As soon as I unplug the monitor, everything goes back to normal. If I plug in my old BenQ, there are no noticeable issues. It is also worth noting that if I reduce the Crossover 289k to run in 1080p, I still notice the performance drop.
The 4k secondary monitor is plugged in via HDMI, and I do have a Mini DisplayPort, but no adapter to try this yet. Could using the HDMI port really be the issue here, or is there something larger at play? I do not have CPU, Memory, I/O metrics at this time (will upload when home if needed), but last I checked they were not significantly different than usual.
DISPLAYS:
Attached 18.4" 1080 laptop monitor and 28" Crossover 289k 4k secondary monitor
DISPLAY MODE: Extended
Secondary Monitor attached via HDMI (have not been able to try Mini DisplayPort yet - no adapter)
SYSTEM: MSI GT80 TITAN SLI-009:
CHIPSET: Intel HM87
OS: Windows 10
CPU: Intel Core i7-4980HQ 2.8 GHz
L3 CACHE: 6 MB
MEMORY: 24GB DDR3L
STORAGE: 1 TB HDD (approx. 50% free) + 256 GB M.2 SSD (approx. 70% free)
GRAPHICS CARD: Dual NVIDIA GeForce GTX 980M SLI
VIDEO MEMORY: 16 GB GDDR5
DISPLAYS:
CHIPSET: Intel HM87
OS: Windows 10
L3 CACHE: 6 MB
MEMORY: 24GB DDR3L
