Hello,
I have a problem where if I have my second monitor connected to my GPU it causes stuttering on the desktop and in all my games. If I disconnect, everything works perfectly.
My main monitor is 144hz and my second one is 60hz. The second monitor goes from VGA from the monitor to a DVI-D slot on my GPU. (Windows recognizes is at HDMI - HDTV?)
And if I turn on my iGPU and try to connect it to my DVI-D it doesn't work. It worked the first time but not after.
Then I tried it on my DVI-I and it doesn't work until I open Task Manager once. At that point I keep hearing a connecting/disconnecting sound.
This also keeps happening:
It shows up as 2 monitors perfectly fine at first even though it's not recognized by NVIDIA control panel.
Then it adds a 3rd monitor while making the 2nd smaller?
Then when it disconnects it goes back to 2 monitors. Repeat.
Thats all I have so far, any suggestions would be appreciated.
