Question Second monitor no signal
Feb 24, 2022
Hello all.
I appear to be having an issue with my dual monitor set up. Upon starting the computer, often only 1 of my 2 monitors will work. The other will show no signal and then turns off. Done all the basic checks, no issues with the monitor itself, right HDMI source selected etc.
Then I decided to unplug the monitor that was working fine, and upon restart the monitor that wouldn't start suddenly worked perfectly fine.
After a bunch of restarts currently both are working, but it is quite a hassle having to fix this every time the PC is turned off.
Does anyone happen to know what could cause this issue? It seems like the computer has trouble starting both monitors at the same time, but I'm not sure what is causing this.
Any help is greatly appreciated.
