Second monitor not being detected. Graphics card updated.
d0nnnn
Hi! So today I updated my Windows (not my choice...) and when the update finished and I went to log into my computer
I realized my second monitor was not working. I have tired everything I can think of, I have updated my drivers, checked
all of my connections, switched ports, restarted my computer, literally everything I can think of and nothing has worked.
I built this computer myself and when I added a second monitor (about a month later) I remember having SOME issues but nothing
I couldn't figure out, now I am completely stumped.
I'm going to explain my setup a little bit so it helps you guys out:
-NVIDIA GTX 1050 Ti (VGA, HDMI, DVI)
-Two monitors (Acer-Main, LG-Secondary)
-My Acer (main) is plugged into my graphics card and is plugged into the HDMI slot, no adapters.
-My secondary monitor is using an HDMI cable and is then plugged into an HDMI-DVI adapter (Benfeel brand)
If you guys need anymore information let me know! Hopefully I can get this problem fixed as having one monitor sucks after being
privlaged for having two! Thanks you guys so much!
-Don
Try going to the Manufacturers website and downloading drivers. For your GPU specifically, and if your monitor needs anything to run properly on this version of Win10.
Yeah, I couldn't detect any through windows setting and NVIDIA settings.
