Second monitor not responding
Hawkins_
8
So I recently got my second monitor and plugged it in via VGA but it automatically goes into power saver mode. Please help.
While the dvi is disconnected the vga acts as it usually does, by stating that it is in power saving mode. Upon re plugging my dvi back into the computer, my icons had been shifted around the screen as if they were configured for the size of the vga. This gives me the impression that the computer is recognizing the vga when it is plugged in but the monitor itself is not registering. When the vga is unplugged it turns fully on but goes right back into powersaver mode upon being plugged back in.
I doubt that not using a cable for a few months would cause it to fail, but I may be wrong. That aside, was it the cord that was causing the issue?
If you have a spare VGA cable, then try it on your second monitor and see what you get.
