Question second monitor only detected when re plugging display port again
The great_1
21
I've installed the fresh copy of windows 10 and my other monitor can only be detected when I unplug and replug it back to the graphics card
I again did the complete install of previous windows 10 copy on which everything was working fine but the issue still persists
I also dual boot windows 7 and this problem has seeped into 7 as well
this happened once when I disabled CSM mode in motherboard but reverted back on enabling CSM (compatibility support mode) but this doesn't help either now.
this only happens when I restart windows 10 through OS, but when I shut down and start the system, everything works fine
the problem can be temporarily solved if I go to device manager and disable and enable again the graphic driver
configuration
Processor: ryzen 1600
motherboard: Asus prime b350-plus
Ram: 8gb corsair vengeance ddr4
graphics card: Zotac 1050 ti mini
Storage: wd green 1tb
PSU: corsair vs550
Monitors
  1. AOC I2080SW
  2. Acer HA220Q
