Second monitor problem
Brainlagg
I want to have 2 monitors working but the second one does not get detected by my computer.
My main monitor is working fine, no issues and is connected to my graphics card (EVGA GTX 960 http://techreport.com/r.x/gtx-960-cards/evga-flat.jpg )
The graphic card does not have two connectors ( look at the picture ) so i connected my second monitor ( VGA ) to my motherboard it's a gigabyte ga z170xp (http://i1.wp.com/blog.newegg.com/blog/wp-content/uploads/UD5-2.png )
I looked in the bios to see if i can set my motherboard to accept input from the VGA motherboard connection but i cant find the option.
Please help and thank you in advance
There should definitely be an option for this in your BIOS, I had the exact same problem with my old rig, and it took some digging and watching youtube tutorials, but there should be an option.
Have you looked at a manual or tutorial for your specific BIOS interface? It might not be that clearly labeled, I know mine wasn't.
i will do some research on it Thanks for the advice
