Second Monitor Problem
Bazyks
40
Hello.since i bought my new GTX 960 the hdmi from pc to TV stopped working.It would either be a faulty hdmi(please no T.T) or the power supply is too low.I have a FX-6300 OC to about 3.8.A 550W is good enough for dual monitor?
As far as I know, dual monitor usage doesn't impact PSU requirements. And 550W should be more than enough for your OC CPU and GPU.
Maybe you simply need to setup Windows to use the TV as a second monitor using the Display Settings.
If it seems more physical tan software, I would do some detective work:
- Test with other monitors or TV's
- Test with other HDMI cables
- Switch HDMI cables from Monitor <-> TV
- Test with the other outputs from your GPU (DVI, VGA, DP)
Good luck!
I don't have another monitor or cable but before buying the gtx 960 the setup worked with the same cable and the same TV.As for the Setup..isn't it just plug and play?
