Question Second Monitor recommendation for work.
Nov 16, 2019
5
I'm looking for a second monitor for work/productivity, I have my main monitor PG279q ,
and I need another monitor with probabbly these kind of specifications:
24-27"
IPS panel ( so that I can view it nicely)
60-75 hz will do ( don't need high refresh rate for work)
1080 or 1440p resolution ( Don't need higher than 1440p)
Can be pivoted 90 degrees without mounting, ( Can't drill some holes in my place)
must have hdmi/display port (My pc don't have dvi/vga)
budget = <250$ ( the cheaper the better)
Some of my options are these 2 :
ASUS PRO C624AQH
Samsung Business SR650
Thank you for feedbacks and suggestions.
