Second Monitor Resolution Problem
Apostolis Kennedy
14
Hello!
I have a problem with my second monitor's resolution. When I first plugged it in, it's native display (1440x900) showed up on screen resolution (Control Panel\Appearance and Personalization\Display\Screen Resolution) and all was fine.
But after I restarted my pc, the resolution was gone. I tried creating a custom one from nvidia control panel but it said that my monitor cannot support it.
The problem continues after i unplugged it and plugged it again, and after more pc restarts.
Some info, my GPU is "GIGABYTE GTX760 GV-N760OC-2GD" and my first monitor is ASUS VE228 LCD. The second is Philips 190WV7 (2007 model no drivers I checked).
Can someone suggest a solution? thank you!! :)
(p.s. I know there are other threads about this issue but I posted because it is weird that when I first plugged the monitor all was fine and then it stopped working.. The thing is that the resolution is there but for some reason windows don't show if after the restart)
