[SOLVED] Second monitor stops working after rebooting PC. help
Jul 13, 2020
I have two monitors which are:
ASUS VE228 21.5" FHD
LG 22EA53 21.5" FHD
My specs:
Ryzen 7 3700x
2060 super
X470 gaming pro max
HyperX Fury 3600mhz Cl17
Windows 10 Pro Version 2004 OS-Version 19041.329
Game Ready Driver 451.67
They were working fine in a dual monitor setup, but suddenly my LG monitor stopped working when I rebooted my pc.
I already tried uninstalling my gpu drivers and reinstalling, same result.
Tried only having my LG monitor enabled in Nvidia control panel, it didn't work either.
Disabled XMP, no fix.
Tried other cables, my LG is using an HDMI and my ASUS is using a DVI-D cable.
Hopefully I provided enough information, thanks in advance
Edit:
I can get my LG monitor to work only if I keep turning it disabling and enabling it in the NVIDIA control panel.
But still when I reboot it doesn't work anymore.
Jul 13, 2020
Solution: Lower brightness on your monitor.
I read somewhere else that there is a thing in the monitor which can't output enough power for what it's purposed for. I'm not a monitor nerd so I don't really know what it's called
Sad thing is I can't go with too high of a brightness because it would stop working then.
Jul 13, 2020
