[SOLVED] secondary idle GTX980 expected power consumption
mStuff
80
Hi,
Lately I have had a lot of heavy graphics processing to do on my workstation, rendering it almost useless while working.
I currently have a single GTX 980 in it, and I am looking to get a GTX1060 as a primary graphics card and reserve the 980 for processing.
That means the gpu will only be used as a processing unit, and never be ultilized for anything else.
From my research, the GTX 980 uses around 80W idling, though this I expect is while running the monitor and system graphics.
Can I expect a 980 to spend less power when simply just registered as a passive processing unit?
Thanks,
Sorry, I hadn't independently verified those numbers - they seemed about right to me, but the TDP of a 980 is substantially lower than a 980TI that I was thinking of.
Even then, minimum power draw is mostly irrelevant if you're actually having it do something, anything.
Reactions: mStuff
