Hello all, as the title suggests I would like to be able to see my H100iv2 Pump speed with the SpeedFan program. I can control the pump speed with SpeedFan, but can not read its rpm. To clarify I do not have the H100i set up as Corsair recommends. I have the pump its self on my motherboards water pump header, and the rad fans on my cpu and cpu_opt headers. I have it set up this way so i can control noise levels better. Also, I hate corsair link, so there's another reason.
Anyway, the pump doesn't seem to report its rpm like a normal fan or pump should. Ive only found 2 programs that can read the pump rpm, the first being corsair link, and the second being Asus Fan Xpert 3. I know the H100iv2 is funky when it comes to any program other than link messing with it, so I doubt there's a fix for this, but through the collective power of forums, maybe somebody knows something. Thanks in advance for any replies.
My PC Specs are as follows:
Mobo: Asus Rog Maximus VIII Hero.
CPU: i7 7700k.
Cooler: H100iv2.
GPU: GTX 1080.
Case: FD Define S.
If any other info is needed please ask.
CPU: i7 7700k.
Cooler: H100iv2.
GPU: GTX 1080.
Case: FD Define S.
