[SOLVED] Seeing high interrupt in process latency using Latencymon.
Feb 11, 2022
13
Here is a screenshot of LatencyMon:
View: https://imgur.com/4RHnegH
Here is the text report:
https://textsaver.flap.tv/lists/4lwf
Not sure if people might need my specs:
Operating System
Windows 10 Home 64-bit
CPU
Intel Core i5 10400 @ 2.90GHz 30 °C
Comet Lake 14nm Technology
RAM
16.0GB Dual-Channel Unknown @ 1596MHz (16-18-18-38)
Motherboard
Gigabyte Technology Co. Ltd. B560 DS3H AC-Y1 (U3E1) 28 °C
Graphics
GIGABYTE G24F (1920x1080@144Hz)
VR-4090 (1920x1080@60Hz)
4095MB NVIDIA GeForce RTX 3060 Ti (EVGA) 42 °C
Storage
931GB Western Digital WD Blue SN570 1TB (Unknown (SSD))
Optical Drives
No optical disk drives detected
Audio
NVIDIA High Definition Audio
Power
  • Model
    500W Bronze
  • Wattage
    500 W
  • Form Factor
    ATX
  • Rating
    80+ Bronze
I am new to PC gaming and have no idea how to even read LatencyMon any help would be appreciated.
Edit: While i was doing stuff i got another report :
View: https://imgur.com/lkh3mgu
Text:
https://textsaver.flap.tv/lists/4lwl
ndis.sys is network driver
https://download.gigabyte.com/FileL...012021.zip?v=4107f8cff4a389a23a8a0a648fb29ab9
here is driver, try using it if it helps
if you have another network card like wifi adapter, you should update driver for it aswell
as for interrupt latency, this is CPU comunication latency with hardware devices through IRQ
this one is a little bit complicated....
try updating bios and windows first
and install al latest chipset drivers available for your mainboard
https://www.gigabyte.com/Motherboard/B560M-DS3H-rev-10/support#support-dl-driver-chipset
which is serial i/o, intel management, intel inf which got released today
ok, thank you for the reply i will try these things and get back to you. I think something is wrong with CPU, i just bought this computer and it stutters on games that my 6+ year old PC didnt stutter with :/
I see some of the drivers say "(Note) Win10 20H2 supported." there confusing me on if i should download those or the other ones since i have windows 21H2 just want to make sure i get the right ones. When updating BIOS i have to do it thru a USB right?
nvidia driver latency can be high if you play games in fullscreen or if you play games with different resolution then in desktop
this is okay as long you dont have issues
interrupts are still a little bit high
feel free to read through this, there is link inside for msi utility v3, try switching from linebased to message signal interrupts, that should drop latency a bit
before you do it, make sure you have fresh system restore point, as some device drivers may not work properly in MSI mode (dont wanna point fingers 😛)
