Seeking advice on my shopping cart (low end gaming build)
Root16
Using mostly NewEgg with a few items from Amazon:
Rosewill Dual Fans MicroATX Mini Tower Computer Case FBM-01 $29.99 on Amazon
EVGA 100-N1-0400-L1 400W Power Supply $34.99 on NewEgg
ASRock Z97M Pro4 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Mobo $99.99 on NewEgg
Intel Core i3-4150 Processor (3M Cache, 3.50 GHz) BX80646I34150 $118.49 on Amazon
G.SKILL Ripjaws Series 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9S-4GBRL $34.99 on NewEgg
SAMSUNG 850 EVO-Series MZ-75E250B/AM 2.5" 250GB SATA III 3-D Vertical Internal Solid State Drive (SSD) $104.99 on NewEgg
EVGA 01G-P4-2753-KR G-SYNC Support GeForce GTX 750 Superclocked 1GB 128-Bit GDDR5 PCI Express 3.0 Video Card $99.99 after $10 mail in rebate on NewEgg
Acer G276HL Gbmid 27-inch Full HD (1920 x 1080) Widescreen Display $179.99 on Amazon
I've built computers in the past (over 15 years ago) and I've never upgraded anything more than the RAM, so I'm not too concerned about this build's limited expansion abilities. My interest in games and computer use in general is pretty casual these days, so I'm looking for cheap over cutting edge performance. I may want a Blu Ray player at some point for watching films; and if I end up using the computer a lot, I may get a 3TB drive (but I have a 1TB external drive already). Otherwise, I'm pretty out of the loop with the tech of today and used http://pcpartpicker.com/guide/gcTwrH/entry-level-gaming-build as a starting point.
I have trial of Amazon Prime so I get free 2 day shipping on Amazon items. The shipping on the NewEgg items comes to a scant $5.80
The total for this build is: $709.22
I think this is a pretty good build for the buck, but if you see where I could improve the value of my purchase or if you see of any potential compatibility issues, please let me know!
Thanks,
Jason
MB - Z97 is for overclocking or SLI / CF. Look toward the H97 platform for your budget build..
SSD - Fine choice. Also consider the MX100 as a good budget minded option.
GPU - Upgraded
CASE - There aren't any 2.5" internal mounting locations in the FBM-01 case and it is a ho-hum case to begin with.
MONITOR - Changed to a 24" IPS LED panel.
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($99.99 @ SuperBiiz)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($63.99 @ SuperBiiz)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory ($63.98 @ OutletPC)
Storage: Crucial MX100 256GB 2.5"...
GPU - Upgraded
Storage: Crucial MX100 256GB 2.5" Solid State Drive ($101.98 @ Newegg)
Video Card: Gigabyte Radeon R9 270 2GB WINDFORCE Video Card ($152.99 @ SuperBiiz)
Case: Cougar Solution (Black) ATX Mid Tower Case ($33.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($36.99 @ SuperBiiz)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($12.99 @ SuperBiiz)
Monitor: LG 24MP55HQ-P 60Hz 23.8" Monitor ($147.98 @ NCIX US)
Total: $714.88
Root16
Thanks for the reply! Your expertise has helped me improve my build. I've tweaked the build:
I've decided I don't mind a chinsy case, but still need to decide if I want to pay more to have USB 3.0 in the front, and whether I pay $10 more to get the Pro4 mono instead of the Anniversary. I need to decide very soon, because some of my new egg deals are about to go away.
CPU: Intel Core i3-4150 3.5GHz Dual-Core Processor ($99.75 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($68.98 @ OutletPC)
Memory: G.Skill Ares Series 4GB (1 x 4GB) DDR3-1600 Memory ($33.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($99.99 @ Amazon)
Video Card: XFX Radeon R9 270 2GB Core Edition Video Card ($132.98 @ Newegg)
Case: Rosewill FBM-01 MicroATX Mini Tower Case ($29.99 @ Amazon)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($29.99 @ Newegg)
Monitor: Asus VS247H-P 23.6" Monitor ($138.99 @ NCIX US)
Total: $634.66
Generated by PCPartPicker 2015-02-12 04:17 EST-0500
Root16
Do I need to buy any cables for this build or will they come with the parts?
I'm concerned I didn't see a cable included in the monitor or the graphics card. Is it safe to assume the case or power supply will come with power cords?
Either the Anniversary or Pro4 would be fine.
All the cables for building the PC will come with the MB or individual part. No worries on the internals of the PC or power cord for the power supply. You may need to pick up an HDMI / DVI cable for the monitor if you don't already have one...
