I've been using a powerline adapter for extended Wi-Fi access in the corner of my home and had no issues for a good amount of time, but the adapter has stopped working properly and I've been thinking of buying a second router to use as an AP. I currently only have one Ethernet cable running through to my room from the router that is connected to my Desktop PC.
As the title suggests, I'm currently thinking of plugging in an unmanaged switch to the existing cable to expand attachable devices in my room, and then connecting both my desktop and the new router to the switch. Now here are a few questions:
1. Will this setup cause any conflicts between the desktop and the router? (I am aware of the need to disable DHCP/NAT on the secondary router)
2. If I wanted to use the same SSID/password on the secondary router, what drawbacks are there and are there remedies for them? Is a seperate SSID strongly recommended?
3. Can I get away with a sub-$60 ac router (ie. TP-LINK Archer C5) and not be hit with major performance issues?
Please feel free to give me any additional advice or alternative, better setups that you believe are feasible that don't come at a steep price hike. Thanks for the help!
I have a 400mbps connection (FTTP) and I am primarily concerned about stable wifi access to phones/tablets, but if gaming stability was somehow possible that would also be nice.
