Seeking feedback on build components
PBR600RR
7
It's about time I upgraded my PC as I'm still running Windows XP on a P4 3.2 GHz. That being said, I've had to relearn everything all over again when it came to components - which is why I'm here. I want a do-it-all build as I don't plan to do hardcore anything - no hardcore gaming, video editing, etc. That being said, I do plan to do some gaming and picture/video editing. Again, this would be hobby level type activities, not hardcore/professional editing or rendering. Of course, all the usual office/internet activities will also be done. I wanted to stay under $1,000 including OS (Windows 7), and leave room for possible future upgrades - SSD, RAM and other incremental upgrades.
Please provide feedback based with my current list. Is my power supply total overkill? Any recommendations? I just realized I need an optical drive, but that should be simple to pick out.
Thanks in advance for all your comments.
You only need a Z series motherboard if you plan on overclocking or SLI. If you are going to overclock you also need an unlocked processor (ends in K)
Here is an OC build
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($232.94 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.99 @ Newegg)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard ($128.99 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory ($79.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($52.91 @ OutletPC)
Video Card: Sapphire Radeon R9 280X 3GB Dual-X Video Card ($285.66 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($54.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ OutletPC)
Total: $1010.42
Generated by PCPartPicker 2014-08-05 03:55 EDT-0400
and a non-OC build
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor ($214.99 @ NCIX US)
Motherboard: ASRock Fatal1ty H97 Performance ATX LGA1150 Motherboard ($106.95 @ SuperBiiz)
Total: $970.43
Generated by PCPartPicker 2014-08-05 03:56 EDT-0400
Thanks for the info and build options! I do have a question. It looks like MOBO only supports up to DDR3 1600, so could I find reliable DDR3 1600 RAM for cheaper? I undersstand the 2133 can work with the 1600.
Update: The G Skill Sniper 2133 you listed is cheaper than the S Skill Sniper 1600...
