Seeking HD cloning soft with guide.
makugx
124
Greetings
I'm doing research but not finding any HD cloning software around.
There's some guides on youtube but I'm not trusting them much.
I found acronis, but I didn't find a trial that would let me clone.
Anyone's got any suggestions?
Thanks!
In 10 minutes, you downloaded it, installed it, figured out how it works, tried it...
and you got a fail?
OK...drives sizes and types? Source and target.
Was the current source drive working perfectly before?
Yes. I read that response and got on it as soon as I read it.
the drives are both SSD 250GB. The one I'm cloning from, I ran error checks, deleted everything, cleaned it up and it has about 30B of USED space.
one is CRUCIAL (SOURCE) and the other an EVO (TARGET)
The new HD has 0 used and 244GB to use.
Crucial didnt seem to work perfectly fine.
Actually I solved it.
It's because when I installed the new drive I was going to leave as the new main drive, I switched their positions on this ASUS G74SX that has 2 drive ports.
the 2nd drive has a little cable that goes to it, but the main seems to go directly to mobo.
I think that's what the problem was.
Thanks everyone who contributed. Hope this helps someone in the future.
