[SOLVED] Seeking help with PC Build that keeps resetting.
To Whom may want to be Concerned with this nightmare
Recently i built a new Desktop pc
Buil info - https://pcpartpicker.com/list/VP88vW
the computer kept resetting when trying to install windows from a usb ( İ also tried other OS's it still resets while installing the os) after some tinkering for reasons i still have not been able to figure out i managed to install windows, however the system resets itself with a Kernel-Power error 41(63)
details are below
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 03/11/2020 16:15:26
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-IRD1M09
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>8</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2020-11-03T13:15:26.4079847Z" />
<EventRecordID>17358</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-IRD1M09</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">132488828963579454</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
</EventData>
</Event>
and sometimes when im playing a game instead of a full reset the game crashes triggering an event called Display 4101(Display driver amdkmdag stopped responding and has successfully recovered.) the details are as follows
Log Name: System
Source: Display
Date: 02/11/2020 22:35:09
Event ID: 4101
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Description:
Event Xml:
<System>
<Provider Name="Display" />
<EventID Qualifiers="0">4101</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-11-02T19:35:09.3368528Z" />
<EventRecordID>16967</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
<EventData>
<Data>amdkmdag</Data>
<Data>
</Data>
</EventData>
</Event>
İ have tried various methods mentioned in other posts on this site and many others to no avail the only thing that worked for a bit was changing the PSU to an 350w non modular old PSU with it i could not connect the gpu but the system would no longer reset when playing a game or without the GPU installed however when i plugged the GPU to my 750w psu while the system was running of the 350w one it would still reset when playing a game or give the aforementioned display error i have changed the PSU under warranty with a new one but that did not solve the problem.
One other thing is i cannot see the post screen when the system is booting or the bis screen when connected to the gpu output and the internal output does not display anything the only way i can go into the bios is by unplugging the GPU and using the İGPU to get into the bios but as i said i can only get into the bios with this method as if i log into windows afterwards the system resets itself.
İ would greatly appreciate any and all input as a this stage a have no more ideas about what to do.
that seems to be the most likely solution but since i already got it changed with a new one under warranty i figured it might be something else unless the PSU model itself is the issue and its not specific to the one i got. still wanted to prod around the net to see if someone more knowledgable than me might see something i am missing.
