I've spent many days reviewing articles and posts in order to configure a desktop. I'm looking at this configuration posting as my semi-final exam (my final will be actually building the machine), so any feedback at all would be much appreciated.
Here is the component list: http://pcpartpicker.com/user/TedT/saved/3l3I
This rig will be 50/50 work and gaming. Work will mostly be Office 2013 applications, with photo and (very basic) video editing. Gaming will be single monitor, 1080p, first-person shooter and flight simulators. Overclocking will be mild (to start). Budget is $3K.
The two 120mm Noctua fans will replace the H100i stock fans, and the 140mm fans will replace the stock case fans. I don't plan to SLI near-term, but would like to retain the option to add a GPU and one or two additional monitors.
My goals, in order of importance:
1. Reliable
2. Fast
3. Quiet
4. Reasonably able to upgrade CPU and GPU (components and config) without needing new MB, PSU, etc, for at least a few years.
Some questions:
What pieces/parts/materials do you recommend to have on hand when building, that are not normally supplied with the components?
Any compelling reasons to go with a larger OS drive than 256 GB?
1. Reliable
2. Fast
3. Quiet
Some questions:
