self built pc is not lighting up when i plug it in
TeraNovaSavior
Commendable
Jan 6, 2017
35
hey guys i built my pc just now but when i plugged in the power supply only 2 small lights on my graphics card lite up nothing else did. the computer wont turn on either when i click the on button nothing happens plz help.
Intel Core i7-7700K 4.2GHz Quad-Core Processor
NZXT Kraken X62 Liquid CPU Cooler
Gigabyte GA-Z270X-Gaming K5
Seagate Barracuda 2TB
Samsung 850 EVO 500GB
Asus GeForce GTX 1080 8GB STRIX Video Card
NZXT H440 Designed by Razer
EVGA 750W 80
https://drive.google.com/open?id=0B2Xgw0RqTsEnWjlkWWI5TUJER1k
https://drive.google.com/open?id=0B2Xgw0RqTsEnWEVLY1ZISXRFMkk
Check nothing's touching the case and shorting.
Check CPU's seated correctly.
Then connect only the motherboard to the psu and see if it goes beep.
If it does, add components one at a time until you find the culprit.
ok so i took out all the componants and only plugged in the motherboard to the psu but there was no beep i think its either the wire or the motherr baord im not sure
