senfu cooling system ¿?
G
Guest
Guest
Hi guys!
recently I´ve purchased a cooling kit from senfu with submerged pump included. This pump was rated to allow a flow of 200-700 l per hour. I´ve tested it with the 6mm tubing included and seems that it could take 5 minutes to pump 1 liter. It´s that enough or is there something wrong? maybe the pump is too weak so.... is a better solution to use a eheim rated at 1250 l per hour?
Thanks to all of you....
